need fiberglassing help
shady
1 ton status
iowa
I mixed up some resin and used it and it isn't hardening......:dunno: I was making a small batch and used what seemed like too much hardener to me. But I figured id be using it fast so it was fine.......
but its been over an hour and its still a viscous liquid :confused:
what do I do if I didn't have enough hardener in it...?
I had a batch harden in the bowl the last time I made it up.... I don't know whats different?
It'll just take longer to harden. Is it colder out than the last batch you made? You could add heat to speed up the process, like a space heater or heat gun. Just make sure it's not in a confined area that the fumes will build up in.
its in my garage..... but the fumes are getting into the house so doors are open now.... its cold in there.... but it was warm in there for about a 1/2 hr
You're taking heat away from an exothermic reaction. If you make up a batch and add lots of hardener to it you'll notice the container gets too hot to pick up. Yeah, I experimented once and my plastic container melted from the heat. :eek1:
I had something I made that didn't set right away. Came back to it the next day and it was hard.
What did you make, or is it top secret?
I pretty much do glass work daily..
polyester resin and MEKP hardener reactions are based on percentages.. %'s can vary from .5 to 5%. depending on temps and other factors, type of repair, thickened, type of glass, etc..
as mentioned, just throw a bit of heat to it for 10, 15 minutes, heat lamp or gun, stop and let cool, it'll be dry within the hr..
a word to wise for people playing with poly... the strongest results are with lower percentages of hardener... yes, higher %'s will kick it quicker/hotter, and harder initially, but also be MUCH more brittle... sometimes that's not critical, sometimes it's MUCH more important..
I could definitely write a book on fiberglassing... :haha:
thanks guys.... heat lamp on it now. its for my speaker box and on my kick pods im making. hopefully ill be able to get a bunch done on my burbs stereo while my kids blazer frame is getting sandblasted and primed. gonna be busy when it gets back
That's good to know - stored for future glass work.
I was just experimenting with that batch when I added an excessive amount of hardener, didn't use it for anything.
I'm sure that's mentioned in this book I have. It's been many years since I read it.
http://books.google.com/books/about/Fiberglass_Composite_Materials.html?id=ileMYXGZ3OQC
another tidbit most don't know is how quickly and violently poly resin kicks is not only based on MEKP % and temp, but how vigorously it is mixed..
if you take 2 different gals of resin, side by side, add the same hardener to each, mix each for one minute, one with a paint stick, the other with a paint mixer in a cordless drill, the whipped one will kick MUCH quicker and hotter..
heat lamp did it. :waytogo: I also turned the heater on and just dealt with the smell in the house. it cleared up rather quick though..
thanks again guys :thumb:
