need fuel tank info please.
sweetk30
Back to play nice .
in the back of your brain
my moms resto of a 73 mustang is ready for the fuel injection system. i need a good way to plum the return line to the tank. what is the best way to do this. i have a new tank that hasnt had gas in it yet. and the sender has been out for about a year. so if i need to weld a part on i can do so. i have a state and government certified welder person at my disposal for this job if needed. thanks for the help.
I wanted a drain plug for my fuel tank and so I took it to a radiator shop and the soldered a fitting from a radiator and installed a plug in it . i also kow a fell who used the charcal canister line and use it for a return line . Hope that helps
i need to run a return line from the efi system, to the tank. it has only 1 line on it. its a single line system now from factory.
but will that sender work with my 73 tank and fit the hole . this is a edelbrock pro flow setup with return line from rail.
