need gm steering column help WIRING gurus?
juanblzer
Chandler, Arizona
my best friend is going to custom fab a steering column (buggy style with removable steering wheel) (bar stock with PTO ujoint or yj column)
anyway...
He is running a 1990 gmc jimmy fullsize with the factory harness. What plugs or wires on the column go to:
ignition?
turn signals?
hazards?
Thanks for any help.. it is much needed
Oh , and BTW , I did discover they changed the pinouts of tilt columns at some point . Jason and I both used whatever column we had with whatever wiring we had in our truggies .......... crank but no start with the wrong column . I ended up with tilt in the truggy :laugh:
Scanner crapped out , I had the TBI harnesses on the PC , the others still in book . I will try to scan later , but heres the colors :
yellow on ignition switch = from start in ignition switch to neutral safety/clutch in switch where it turns purple
brown/white on ignition switch = from run in ignition switch to alternator
red on ignition switch = to battery positive/starter which jumps to alternator too basically all would tie to junction block
purple on wiper washer switch = to wiper motor , joins one of the greys there ( there are two greys on wiper motor , joined in the harness )
black/light blue on wiper washer switch = to wiper motor by itself
grey on wiper washer switch = to wiper motor , this turns into two in the harness and goes to two spots on wiper motor
pink on wiper washer switch = to wiper washer motor
pink on ignition switch = to tbi distributor
light blue on turn signal switch = to left front turn lights
yellow on turn signal switch = to left rear stop turn tail lights
dark green on turn signal switch = to right stop turn tail lights
dark blue on turn signal switch = to right front turn lights
purple on hazzard switch = to flasher
brown on hazzard switch = to convenience center
white on hazzard switch = to brake switch
yellow or light blue = from dimmer switch to headlight switch
tan = dimmer switch to headlight low
light green = dimmer switch to headlight high
And thats all I can gather from my book . Hope I didn't miss one :D
