need good head!
fjleiter
Palmyra, NY
Ok, get your minds out of the gutter... Rebuilding the engine in my '90 K5, has the K-code L05 350. Need to get new (rebuilt) heads for it (current ones are bad ie: ones cracked).
What are acceptable heads to use on it that aren't going to cause problems. I don't mind using an aftermarket intake (actually it's the plan!) but don't want heads that will drop the compression. Non-vortec (or non-swirl port which this one has) are fine, especially since an intake would be cheaper but don't want to drop compression or lose performance.
Any ideas or specific heads? Keep in mind I don't have the money for aftermarket style heads etc... Just looking for basic rebuilt heads.
Vortecs all the way. the runners offer an improved swirl over the stock heads, and the combustion chamber has a more efficient shape. GM sells the intake you'll need.
go to autozone and tell them you have a 1991 corvette. One head is 170 + core charge. The head comes fully assmbled and it is a aluminum head with 58 cc chambers. Then just take your cast head back a week later and they will never know and you will get your core charge back
complete conversion to L31 Vortec heads is going to cost about $1000 with the GMPP vortec/tbi manifold which costs $300. you gotta get heads, intake, 12 pt. intake bolts, egr adapter, egr adapter fitting, and egr hose (if youve got headers.... if you run stock manifolds, you gotta get a passenger side vortec manifold w/ egr fitting)
World Torquer S/R heads are great. i believe they are about $750 for the pair, but your intake will bolt right up to them, and they dont require the crap vortecs do.
i wouldn't use the aluminum L98 vette heads...
[ QUOTE ]
[/ QUOTE ]
Take this man's advice.
what if you dont have EGR jsut need the heads and intake right? well bolts of course and gaskets....
for a carb setup ona 350
Get a set of iron L 98s. GMPP still makes them. They will bolt right up and come in the center bolt style. They flow way better than the stock TBI heads. 64cc chambers /forums/images/graemlins/thumb.gif
New they cost around 600. But you may be able to find a rebuilt set from a head shop for less.
[ QUOTE ]
[/ QUOTE ]
Do you happen to know what casting number these heads are?
[ QUOTE ]
[/ QUOTE ]
you will have EGR after you put the vortec heads and intake on...... however, the carb/vortec intake costs ALOT less tha the tbi/vortec intake. it is possible to put a egr block off plate on the intake i guess....
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
those are the aluminum L98 heads, but, i have never seen them at that price..... the iron heads cost $600..... the aluminum version definately costs substantially more. plus, i dont know if i'd be comfortable buying a reman head..... ya never know when they could have a crack that was overlooked.
[ QUOTE ]
[/ QUOTE ]
your right...... but, for the money..... they don't make that much more flow, definately not $600 worth..... and they were designed for cars.... not trucks.... you may loose some low-end...... spend $150 more and get the torquer s/r heads..... they are a great truck head, and boost yer low end and high end.
You are not going to lose low end with any factory heads. Hell, the biggest factory heads have 180cc intake ports so so. Even the smallest aftermarket heads are in that range.
Every GM head reguardless of application is going to be designed for low end torque. That is what moves a car down the road during normal road use, and that is what gets a rig through the warranty period. /forums/images/graemlins/thumb.gif
[ QUOTE ]
[/ QUOTE ]
HA.HA..HA...HA, Thats Funny! /forums/images/graemlins/histerical.gif
All of the AutoZones, in my town, have one guy that knows what he is doing baby-sitting a bunch of morons that could not find there a$$ with both hands. Every time I go to Autozone for an auto part, I have to go to autozone.com online catalog first, to look up my own part numbers. If I do not look up my own part numbers, and I get one of the morons helping me, they will look at the computer with a blank stare for a few moments...then turn to me and say, "We don't carry that part" just to save face and make me go away.
I would argue that you are ignoring a critical part of "better" heads. Flow is only half the equation, newer heads have a far superior combustion chamber, and increased efficiency means increased power, no matter how you slice it.
I guarantee you use two identical heads, except one with the fast-burn style chambers, fast-burn will outperform the old garbage handily.
