Need heater hose routing help
BEEBOB
Athens,al
Yes I have search and am still confused. So I changed the heater hoses.
Got pulled away by the wifey before I out them back on.
Not sure if I have them ran correct. Takes longer to heat up now.
So I have the hose from intake to the heater core pipe closest to the motor. And the one closest to fender to rad. Is this correct.
Thank you.
that's how i have mine ran, sounds like you have air in the system
Thanks. Would the air not just circulate out. Or how would I purge the air out.
sometime you get lucky and it will come out on its own, do you have that valve in the heater hose line that stops flow?if not jus let it get to temp and pop the cap and see where
the level is.make sure the heater is on when you run it.
Usually these systems purge pretty well, sometimes the air takes a while to get out. Drive it for a while and get it good and hot, running the heater. Check the level and top off as needed.
