BlueOx
I took the hubs off the 14 bolt axle and was able to get the inner bearing out by just removing the seal. I turned the hub over to take the outer bearing and observed there to be a snap ring holding it in. I thought once I removed the snap ring the bearing would just fall out; not the case. I pounded on the other side to get it out but, no luck. So, how do you get these things out?
Thanks,
Charles
Thanks,
Charles
