sandypants
ok i replaced the sending unit with a new one. i also made sure the ground was good and tight against the frame. cleaned the frame and all. i took it on a test run drove a mile came back and pop. new fuse pop again as soon as it touches the fuse box. im on a time crunch before i leave to germany next mon so im trying to figure this out. do i just follow the wires or is there something else prone to failing.
thanx jeff
thanx jeff
