I have a 91 K5 that is new to me and I am about to upgrade the axles. (D60F and 14BFF currently with 4.56) I am familiar with the one thing leads to another with drivetrain/suspension upgrades so I want to make some long term plans so that I don't end needing to replace something twice. I plan to use a 205 T-case and need some advice on selecting an auto transmission. I will be putting this truck on the road to get to the trail so I would like to have an overdrive gear. What are my options here? After doing some searches and reading past posts here, I am considering the differences between a 700r4 or a 4L80E so I have several quesitons.
(Some other info. I will probably start with 37-38 tires. If I find that I need to go larger I can't ever see doing anything larger than a 44. If I ever need to do an engine swap I will give serious consideration to a crate fuel injection like a 350 ramjet. I will probably never go with a 203 doubler.)
1. My truck has a 350 engine and a 700r4 tranny Correct? If so, do I automatically have the K case I have read about?
2. Is it possible to put an OD gear in a stronger transmission, say a 400, or is the 700r4 and 4L80E my only choices? (I can't afford an allison and don't want the extra weight.)
3. If I put the 4L80E on there now, What type of controller will I need to run it with the stock, non-FI engine? How will that change if I later go the FI route?
4. What are the differences in mating a 205 to the 700R4 and the 4L80E? For example, Can I stick the 205 behind my 700r4 and just change the output shaft on the 700r4 and then later put it behind a 4L80E without making any changes to the 205? Will either of these require a custom adaptor? (I am under the impression that the 205 was never put behind the 700r4 in a stock setup.)
5. Do the 700r4 and the 4L80E have the same length and bolt locations? If I put the 205 behind the 700r4 now and later go to the 4L80E will I need to move the T-case crossmember or the trans crossmember?
6. Do I really want to mess with the computer trans/FI stuff or would I be better off going with a built 700r4 and if I need to do something with the engine sticking with TBI or even going to a carb?
7. I assume any small block swap will result in the transmission staying in the same place, correct? What if I go with a big block? Will that require relocating the trans and T-case?
TIA
TIA
