scpaul
I have a '90 Jimmy 1500 that has around 150K miles. It was parked about 8 years (?) ago because of the price of gas, about 6 mpg, more than anything else. It was bought new by our family, so I have a pretty good idea of the history of it. It's all numbers matching, so I don't want to get too radical.
I used to work/play with automotive stuff many years ago, around 1974, I had a street car running low 13's on street tires. ALOT (everything) has changed since then. I started looking around to find the fine specs on this vehicle and found that somewhere along the line they changed the rules. It has the factory towing pkg. with a load leveling receiver hitch, trans and engine oil coolers, HD radiator, etc.
When I was messing around with vehicles anything, especially a truck, with a tow pkg. had a 4 bolt main block. What I'm finding using the VIN and internet to figure out what I've got.
On one rebuilder's site, he had 2 listings for a "K" code engine in the same list. One inside of the other according to dates. Like (just an example) it says that "K" engines ran from '87 to '95. Farther on down the same page it says that "K" code engines ran something like '88 to '93, just an approximate from my memory. It says that some of the years had a mech. fuel pump hole, others don't. I think that it was the later ones that had a different intake, ctr. bolts different, and inside of intake set-up for TBI. Both say 1 piece rear seal. I've got to look that one up. One group has the possibility of having 3 different heads; 191, 193, or 810 head castings.
At this point I figured that I'd ask somebody. Then I saw one was called a 350L130 and the other was something similar, 350L150? ( guessing).
With all of the things that they are doing with computers now days, I don't know if I could be doing something wrong if I put the VIN in here.
Who is willing to help me (old phart) try to understand some of this new stuff and how to deal with it, and yes, I'll probably wind up being a C.P.A. (Capitol Pain in the Azz). Some say that I have an inquiring mind others say that my memory's gone. I was around in the 60's and 70's.
I found where it says that this mtr. is 9.25/1 compression, which is more than I expected. I figured 8 or 8.5 to1. It says that it has a nodular iron crank and some other things that don't sound like they should have been put on a vehicle with the factory towing pkg. (7K Lbs?), from what I think I'm seeing, this is going to have to stay pretty much stock unless I want to sink my whole S.S. check into it every month. I have heard that canned cat food burger patties is pretty good fryed in bacon grease and put on a bun.....Just a joke, but I bet onions would help it.
I need an education or at least enlightenment. Thanks everybody, in advance, for just putting up with my ignorance, Paul
