I am planning to swap Rockwells with 44's into my 1984 K30 in a few weeks. I don't want it to be wider than necessary so I want to run as much backspacing as possible on my wheels without limiting the steering. I would really appreciate it if those of you already running rocks could provide me with some info.
Thanks in advance,
Mike
Hubs in or out:
Tire size:
Rim width:
Rim backspacing:
When turned to full lock, do the tires rub or clear the frame:
If they clear, do you know the distance between the tire and frame:
Thanks in advance,
Mike
Hubs in or out:
Tire size:
Rim width:
Rim backspacing:
