Need help I mixed up which way the bearing caps go
protechk5
VA
Ok while installing my lockright on my front d60, my bearing caps got knocked over, I know which side is which, but I dont know what side is down or up. Are they always installed the same way? If so I could tell by the casting numbers printed on them. How f ed am I if they go back the wrong way?
Look closely at the cap and adjacent gasket surface, there should be similar marking who's orientation match. For instance -
> > ... or ... V V
I hope that makes sense....
> > ... or ... V V
Ok that made sense after I went out and looked at it, thanks alot its all back together!
