Need help ID'n Dana 60 power lock
b454rat
Binghamton NY
Bought a P/L from a guy off pirate. Trying to figure what it came from, so I know what the carrier break is so I can get the right gears (eventually). I got the number off the case, and looked thru every model of 60, back to in 1967 and cant find it. Date code 2 6 67, case number 24607X. I can't find anything.....
I have a guy, I will ask and get back to you
The Dana expert site only lists it as "obsolete", it doesn't identify it.
Couldn't find out what it came out of, but confirmed 30 spine and 4,10 carrier. Ratio didn't matter too much, could've figured it out, just curious what it came out of. Now I now I need thick gears to use it.
AFA the casting number goes IH was the closest....long as I can make it work....
I think you can find a thick gear for those of you go 4.56 etc
yeah you can....if not prolly be pissed lol...But I could use in a standard rear 60 for the 'hoe.....
