coose1973
just got my lift on and all of my off road design goodies(almost 600 bucks worth and more to follow) on my 79 blazer. new tires mounted on the new wheels not even on the truck yet. headers put on ready for exhaust, am i setting the mood yet? i get to putting on the steering arm or actually taking the old one off. problem starts hard to come off ok no problem i'll heat it up a bit well to make a long story short and keep a family forum clean, the rocket scientist i got it from welded the steering arm on, after further inspection. now the axle that is on the truck has the gears, locker, and everything i want. is there a misalignment setup or end i can go with to solve the constant replacement of tie rod ends? its only a 4 inch lift nothing drastic. i don't do alot of crazy wheeling. i guess i would need a setup to go from the pitman to the steering arm any suggestions? thanks
