dunehopper502
Registered Member
i have a hard miss when acclerating,happens about 3800-4200rpm then clears up and will rev out fine...any suggestions?
this is what i have 90 k5,98 (r)motor vortec with gmpp intake,mild cam,gm roller rockers,msd distributor/coil//6a box/,tbichip programmed for motor,high pressure pump,afpr in tbi,
ive checked timing 0* with est disconnected,replaced map and tps sensor,replaced dist with stock unit,disconnected msd box,newplugs,wirez,ecm,still does it im running out of ideas,the motor was fairly new when i got it and had it gone through and inspected when had cam installed......any suggestions on what to check or do next?
carbed bigblock is looking better and better
