looking at a cheap dana 60 that is DRW. what would i need to do to make it a srw?
dont want to miss a deal out of ignorance.
ironic part of that, 2 months ago i traded my stock h1's with the 37s away for a set of standard wheels with TSLs. id rather not go back to them tho bcuz i have srw 14bOr keep them, and swap wheels to H1 double beadlocks.
Martin
saw something on pirate about machining down the DRW hubs to be used. anyone have the dimensions/ or more details on that part of it?
i'll investigate more after lunch.
***saw it on the 60 bible later on. didnt read far enough down page.saw something on pirate about machining down the DRW hubs to be used. anyone have the dimensions/ or more details on that part of it?
all the ones i've been seeing are $350 on the cheap side without rotors or bearings. 550 for a pair with everything including studs and rotors.dont do it. It is ghetto. Basically not enough mounting area for me to be comfortable, especially on a full size rig.
factor in 300 ish bucks to convert drw to srw to buy hubs
thanks i've been going over and over the bible trying to absorb it all.Lots of info here - Dana 60 Tech
Most often broken parts in the dana 60 with large tires are warn hubs and outer shafts.
Replacing the outers with 35 splines is recommended, but then you have to figure out what you want to do as far as hubs go, several options there...
I will be running drive slugs on my truck.
