Need help on Passenger door window motor
Suburban nation
Registered Member
BelAir, Maryland
I have a 1984 Chevy suburban with power windows all but one door works the rear passenger door goes down but will not come back up .Put new motor and switch in door but steal dose not go up .Have checked the brown and blue wires going to motor and they both have power .The blue with white strip wire coming form drivers door switch has no power . Need help
I'm not sure on that, BUT if you haven't for the heck of it, check the wire harness between the door and body of the truck to see if there's a broke or a frayed wire in there that needs to be repaired.
Tony
