AC130Ghostrider
Registered Member
I've searched on here and found a few threads that talked about this, but I don't know enough about this trans to follow very well.
The problem started after doing some light wheelin. Flexed the front a little and heard a couple pops/thuds. I don't think that had anything to do with it, but then it would not shift in or out of gear. I shut it off and could shift it fine. I made it home with minimal problems. Now when it's not running I can shift it fine, but as soon as I crank it, I can't even get it out of gear. Nothing is visually broke and all fluids are good.
Don't know if makes any difference, but I'm running 1 tons, np 205 twin stick, and 39.5s.
Just noticed I mistyped, it's an SM465, but I'm sure you guys know what I meant.
