Need help....Someone...anyone Hardtop leaks!
DAGRIZZ
Registered Member
Oregon
Hard top issues...
I have purchased the Roof to Rail weather stripping from a few companies. They all leak! This time I purchased from Brothers...I want to know if there is any step by step "with pictures" for installing them properly. I have issues with the mounting to the windshield seal and the wind wing seal. I want to make sure I have everything I need for a 1972 Blazer.
Does anyone know of any tricks or do I just buy rain gear! Thanks for the help!
You didnt say whether you have a single wall top or double wall. The seals are different so that would benone thing to verify.
-Brian
Thanks for replying......its a single wall top and it leaks above the wind wing at the windshield pillar. It seems like the install should be simple, but it still leaks. I'm not sure how the Drip rail deflector and the roof rail seal mount properly. When you close the door the wind wing top hits the Roof rail seal rubber. Do you have any pics on how its installed correctly?
Thanks again
Mine doesnt leak, but i also dont have any seal at all on the windshield.
I do have a leak from the actual windshield rubber gasket though. Are you sure about where the leak is coming from?
-Brian
