itscheesey
Registered Member
Ok now that I hopefully got some of your attention.
I have a 1991 GMC Jimmy About a month ago it started having issues starting so I replaced the cap rotor plugs and wires. Still had issues so then I replaced the fuel filter and it started a little bit easier. Then it got hot as he** out here in Vegas and I started having issues again. So I started researching this. When I went to pull codes there was 14 and 42. So I checked and the PO never put an O2 back in when the headers were put in. So i pulled it and had a buddy weld in a bung and replaced the O2. I also had a spare ESTC laying around so I swapped that out as well as the CTS. Now I am getting a 44 when I pull codes. Im going to replace the EGR. Also I have 10psi fuel pressure. Im kinda lost here and need some help.
The Cheese
The Cheese
