TheBeast_88K5
Banned
I can't figure out what wire feeds my ignition.
I also have no idea where it goes, after the starter.
I thought it was the red wire that leads up to the junction block on the firewall. (next to the master cylinder).
But that appears to have one red wire that leads to a connector on the A/C,
And another that was cut off by the PO...
I have no power to my fuse panel, or ignition after wiring up my isolator, and new battery/starter cables; And, replacing my fried alternator.
I know the cables/wires are all done correctly, as I've checked them 5x, now.
I can't seem to follow the thick red wire from the starter, as it passes behind the engine block, through split loom.
I replaced the fusible links from the starter, and checked the one at the Alt.
Alt has power from the battery,to the sense wire, and through the red wire (after the link), to the firewall side of the fuse panel.
The in cab side of the fuse panel, ONLY has power to the left-most 3 circuits.
I don't remember which they are, but I think it's B/U, CTSY, and something.
So....
BATTERY- 12.3v, new bat>starter wire.
Alternator- new, 94A, new Alt.>isolator wire, good fusible link, sense wire shows power from isolator>Alt.>fuse block (firewall side), but not in cab side(?)
Starter- works, replaced fusible links, has cont. to junct. block, can't chase Ign. Wire behind engine block.
Ignition- has no power when keyed/ haven't checked Ign. switch, yet.
I hope this makes sense to you guy's....
Im just really frustrated, chasing this stupid gremlin around...
So....
