irishraptor87
im putting a new motor in my burb, and i decided to upgrade to the th400 from my 700r
i have been searching and figuring out what i can, but i think i need more info...
so the 400 has an electric kickdown, not bad, im going to prolly end up picking up this part gm# 1242101, which is the switch that goes behind the pedal to make it switch over, fairly simple, i can do that
on the other side of the tranny, there are what look like 2 ports for cooler lines, i can run those on my own.. easy
then theres the dipstick, which i got with the deal, so that can be taken care of
but next to the dipstick, sticking out horozontally is another hole... i dont know what this is honestly, i would assume it is the vaccume that controls shift points, i have never had a 400 so im not sure, is there supposed to be a fitting in this hole, and how should i run i line, i got nothing in the deal having to do with this, do i need a modulator in-line to my carb
lastly, he didnt have the flexplate to this, what flexplates are compatable to this tranny, i have a spare one from a 83 th350, would this work, id like to save some money
all help is greatly appreciated!
cory
cory
