Seems like these are kicking my ass for some reason. Part of the complication is that I'm not running an air pump. It also looks like the previous owner didn't have the power steering pulley pressed on all the way so he wasn't using the correct pulley grooves. Beside the fact I didn't think to even keep the old belts.
I need to know if anyone has part numbers for the 2 belts I would need. 1 will go around the CRANK, WATER PUMP, and ALTERNATOR. The other will go around the CRANK, WATER PUMP, and STEERING PUMP.
Or how do I measure for belts? String around the inside of the pulleys on the bottom of the groove or around the outside of the pulleys.
