need help with doubler boot.
rhinoblzr
hey, guys i had a little time over the weekend to fab my trans tunnel up but ran into a problem with the 203 doubler boot from ord not having enough throw. just wondering what what you guys are using. you can see how much longer the 203 throw is in the pics.
Mine fit within the ring that came with the boots. Is your tunnel a lot higher than stock?
There's an oval that fits the boot, then a bigger one that fits both boots.
I have the ovals inside each boot. The big two oval piece would of stuck out of the passenger side so I decided not to use it. Yes it is way higher than stock so i can put my tuffy box on top and use it as a arm rest. The 203 boot cant stretch far enough.
Awesome thank you for getting the ball rolling i'll sift through all those and see which one I can use appreciate the help
