Ok, so I have a 77 k20, sbc350, th400, drivers drop np241, new balenced driveline, new 1410 ujoints installed professionally, fully rebuilt axle and a newly installed anti-wrap bar. It has new engine bushings, and new trans bushings. I have a pulsing vibration at 65mph not lower and goes away If you go alot faster like 75ish. My t-case angle is down 6 degrees, my driveshaft is down 10 degrees and the rear pinion is up 7 degrees. It's operating angle is is -4 at the trans and -3 at the pinion. The total if I'm doing the math right would be -1 wich is suposably close to perfect. What am I doing wrong?
