Need help with my stepsons truck. Long story short, his dad had his mechanics convert his truck to FiTech so I wasn’t part of the install process. Had to fix issues here and there and learn how to program a lot of the settings on the monitor. We have had it running great for a cpl months. Had an issue other day where it wouldn’t rev past 2500 RPM. Found breaks in the distributor wires. Fixed that. Doing fine until today, turned truck off, then won’t start. Sprayed starting fluid, runs off the fluid which leads me to believe the pump is bad (only couple months old). The pump (in line pump, I think FiTech brand black) sounded different than usual after turning the key on, usually it has a consistent “tone” but after it didn’t want to start, it was “pulsating”. Gave up for the night but my plan was to run to AutoZone in the morning and grab a new pump for it. What pump does everyone recommend I should get? What works well with this system. It’s the go street 400 system. Thanks
