kodiakisland
Registered Member
I have a 91 stock 350 with TBI. I have had no problems until this week. The Jimmy started fine but died within a mile of the house. It is very difficult to get started and keep running. The motor surges and then almost dies, then surges, almost dies, and keeps that up until it finally dies or I turn it off. The exhaust smells like it is very rich, but there is no smoke of any kind coming out. The motor dies if put into reverse or drive. In park the motor will die if the gas is pressed quickly. Pressed slowly, it will only rev slighting higher than what it is doing at idle before dying.
I know absolutely nothing about TBI systems. I assume since I have fuel the fuel pump is working and fuel filter is not clogged. Fuel pressure regulator? Where should I start to see if it is the TBI? There are no check engine lights on.
It has been over 100 every day this week but it hasn't been driven more than 4 miles at a time. Could part of the ECM, ICM, or some other electrical system be fried?
