Need help with new truck
53chevy
pitcairn
HI, i just got a 84 GMC 1 TOn with 12 inch lift and 39.5 boggers. It has 5.13 gears in the 14 bolt in the rear. How do i tell what gear ring size and if it is FF or Fs axle. Reason i need to know is i need new rear brakes and want to do a rear disk conv. Thanks for your help
Well, if your cover has the same shape as this:
then it's a 14 bolt full float. The ring gear size is 10.5". If the cover is more of an oval shape, it's a semi float axle and the ring gear diameter is 9.5". Another way to tell is by looking at the hubs. If there are 8 bolts on the end of the hub, it's a 10.5" full floater.
A 14 bolt FF has 8 bolts that go through the axle flange into the hub. This is not my pic, I grabbed it from the web.
If it is infact a 1 ton from the factory it will be a 14BFF unless it was swapped out for some reason. Just look for the large hubs sticking out of the center bore of the rim. Like pictured above.
