roadie114
Registered Member
Hi guys,
I have an '85 K5 Blazer with a rear window that has a manual crank. I recently have been trying to rebuild it, and have replaced the actuator (clutch was slipping) and it's working fine now. But I need help reassembling the tailgate latch. The spring on the hinge assembly was loose and not in place when I found it. I'm having a hard time seeing where the window up position "interlock" connects to the hinge assembly, and also how/where the spring is connected. I've looked at the LMC drawing on page 44 but these components aren't that detailed. Can anybody take a pic of their setup, or guide me in the right direction? Thx!!
. I noticed on the latch assembly there is a hex bolt that isn't a mounting bolt, but rather an adjustment bolt. My rods don't release properly (too loose or too tight), is that what this bolt is for? Thx again.
