Adventurous 4x4
Ok, bottom line is I hate wiring. What I have is a 90 K5 with a 350 TBI. It is getting hacked, tubed, and the dash is gone. I am also removing the stock steering column. I know I can buy a aftermarket harness to run the FI but I don't want to spend a few hundred bucks to get basically what I already have. Does anybody know of a place that will modify my harness? I will be getting rid of the vss and also need a "check engine light" for the codes. I searched online but couldn't come up with anything except premade harnesses. Here is what it looks like now and I don't need much wiring for anything else because I will only need a ign and starter button, and it will have 3 guages. Oil pressure, coolent temp, and volts.
