Need help with TBI
mudlover88
Newbie
Houston, Texas
I have a 88 K5, 350 TBI that has laid down with a no start issue. Have new plugs, wires, tps, map, esc, egr, egr sol, o2, new dist, coil, and yes new fuel filter. I have swapped the ecu, and the fuel pump relay. I have fuel at the TB, and spark at the coil. WTF am I missing?:D:haha:
fuel pump? it could not be getting enough fuel, does it seem like it wants to fire? how does it act?
pull the injector connectors off and see if it starts and starting fluid, go from there, could be a timing issue or compression
