I am having a problem with my 87 k5. When i put it in gear it dies. It will idle just fine in park. You can even power break it and runs just fine. I don't know what it is. I did replace igniton control modle.
Have you checked for vaccum leaks, broken/cracked vac lines, TB base gasket leaks?
Have you checked for trouble codes?
Tune up. Plugs, wire, cap and rotor?
