mecheng
Registered Member
Hello guys I just got a 91 c1500 with a 350 engine. When I got it the head gasket was blown and one of the heads was cracked. Well I got another head took took it to napa and they did a valve job and resurfaced them. Well my problem is that I disturbed the distributor and now it doesnt even start. Well I was trying to follow the cheltons manual on how to set the timing on a default position (you know cranking the crank pulley until it is on the mark of cylinder 1 and then do some other stuff) but when I was trying to crank it it had some misfires and then I stop cranking it and after 3 or 4 seconds the engine burped blue smoke. It made an air noise and all the smoke came out. It scared the crap out of me I thought It was in fire. So first I want to know if those were signs of a blown engine or what could that be? Also need some tips on how to bring the truck to start again so I can use a timing light. Thanks a lot
