Blazer79
I did search, but only got more confused.
I need to replace all the U-joints in both my driveshafts.
The front driveshaft is the stock 1979 driveshaft. It has a CV-Joint near the flange at the transfer (NP203). I found that these should be 5-3147X on the CV, and 5-153X near the axle. But another site said these part numbers were obsolete but didn't mention new, another search mentioned part No. 5-1306-1x for the front. Also, these appear to be greaseable. What are the non-greaseable part Nos.?
For the rear driveshaft, I'm running a CV with same U-joints as the front CV, so it's easy once I figure out the front one. On the axle side I found 5-178X and 5-153X. Which one is it?
I have a Dana 60 & 14 Bolt. Both had the same yoke size as my old 10 bolt & 12 bolt, and fitted without any mods to the driveline.
I suggest there should be a sticky with common part numbers.
Thanks for your help.
