Need Help
bigtyme9977
Registered Member
north dakota
i need some advise on what to do here.i started my disc brake swap on the 14bff and ran into a problem.one of the bolts that held the drum back plate on was stripped and also the threaded hole on the spindle.just looking for my best option here,drill out a bit and put a nut on the backside,put bolt through and weld,just tap and put a bigger bolt in..thanks for the help in advance.it is the bottom one in the pic
attachment.php
Pic no work :dunno:
if a larger bolt doesnt work then a high grade nut and bolt and lock tite would work
looks like its slightly ovalled out already I would just nut and bolt it.
Use a grade 8 Nut bolt and washer, dab of loc-tite and your good
