need ideas as to where to cut up a 68 gmc burb
55Willy
3/4 ton status
Keizer, Or
I had one given to me from a friend and all I want is the trailing arm set up and the column out of it. i'm gonna rat hole the 6 cyl out of it for another project and just have this thing sit on the back burner til the other 68 is done. with the rust that is in it would ya cut it up into a crew cab truck with flat bed or just swap on a truck cab and bed?
the end result is i want to build a prerunner out of it, someday....yeah right :wink1:
Dude, weld the back cab surround, from a truck, to the burb, just behind the back door, and make a crew cab 68; or some kind of 68 Avalanche.
Do it . . . do it . . .
i was a little confused where you selling or giving it away or starting another project.. where is cornvalley
cornvalley is corvallis oregon
i had the burb giving to me,
i was trying to sll it to fund my other burban...but
have decided to just rob the parts i was gonna fund by selling by just robbing them off of it. so I started cutting it up
the steering column and trailing arm set up will end up under my other 68 burb.
got ya was looking for one not in a rush but saw this and was intersted. but you are a little far away,
all i can seem to find is 2x so i might have to do a swap.
