Need measurements please.
Samhenley06
Registered Member
Huntsville
So I'm about to do the 14 bolt axle swap. I have a 6 " lift, 37" tires, 700r4 with np241 transfer case. Does anyone know the measurements for the drives haft so I can get it made before I do the axle swap so I'm not down waiting on driveshaft.
SYE or no? To get by in the mean time, you could probably run your stock shaft with a conversion u-joint (I am still "getting by" with a stock shaft and an 8 inch lift in my K5). Not ideal, but should allow you to get in and drive it.
Don't do it. Too many variables. Measure once its done. Tom Woods got me a driveshaft same week with shipping.
X2 on this one. If your just swapping in the 14 bolt and no other changes at the same time you could probably get by with the shaft you have and order for tom woods they have quick turn around usally. A good product and good service in my experience. Also if your current shaft and the 14b have a diffrent u joint size they sell conversion joints at auto part stores that are one size on 2 bearing caps and the other size on the other 2 bearing caps.
