Correct except the part where you said that the waterpump line is return.
The water pump and or (I say and because you can try t'ing them together for more flow!) intake lines are your IN to the heater core.
There are two answers to the above I suspect...A) it's incorrect, or B) it depends on the water pump. I suspect it's B.
The water pump fitting I have is "in" the flow of the impeller, and looks like it probably enters in BEHIND the impeller. It's not past the pump where pressure is built. I've hooked mine up to the pump, and heat was non-existent. I *believe* there are water pumps with the fittings in a different location, but mine faces the passenger side of the truck.
The OP needs to check engine temp first, which it sounds like he is doing. Could be a 160* for all he knows!
