Hey all, back to get some ideas on my 2000 ZR2 blazer, 4.3Vortec, $wd, ac all the goodies
Symptoms - Ran Lousy, hesitated often, died occasionally, now it won't start. new alternator, battery and fuel pump (other issues), replaced in the last 18 months.
First no start:
Cleaned the Cap and rotor, reinstalled started but ran lousy down the road under load. Seemed to run ok under full throttle. Had a scanner on it, only code thrown was Multi Spark Discharge, once it was cleared no more codes, but still ran lousy.
The Distributor had a plastic ear broke off which kept the cap from screwing down tight so I replaced the Distributor, cap, rotor with a Summit Metal body. Still no start, swapped out the pickup in the distributor and still no start.
Checked plugs, re-gapped, all fired.
Checked fuel pressure, 60+ PSI at the back of the throttle body (on fuel pump #3).
Thought maybe a clogged Catalytic converter but it has decent pressure at the tail pipe while turning over.
Tried spraying starter fluid in it doesn't even act like it wants to start but did backfire. Tech said try starter fluid, if it started then died it would be the injection spider system; if it didn't it would be a computer issue.
Picked up Computer off ebay for $50 swapped it, still no start, stole the neighbors computer swapped it in, still no start, mine worked in their truck...
What else can I try? I'm stumped... probably something electrical or something stupid I'm forgetting...
When the Hazzard lights/ turn signal was replaced under recall about a year ago they put in a new ignition switch in the column as well as relays and turn signal level... so I ruled out ignition switch since it ran after it was replaced and was running poorly before it was replaced...
Coil maybe? It has fire at the plugs...
Ideas?
First no start:
Ideas?
