Need new springs
thekevin
Harrison, AR
So my rear springs are worn out, even after new shocks I still hit the bump stops going over speed bumps. I have looked around and all I can find are lift springs out there, any idea where I can get some new stock height springs.
LMC website or JC whitney I hear has them as well. Otherwise just pull them off a salvaged one that look good. will save a bit of money I'd guess.
I looked at LMC, they are 250.00 for both sides. I noticed you are getting ready to upgrade axles on yours, are you going to use your current springs or upgrade to the 3/4 springs. I found a rolling 78 3/4 ton and I thought that I might just move over the axles and springs. They are direct bolt in's right.
I'll be keeping the springs I have when I do the upgrade. I would plan on checking out the salvage yard that will be your best bet I think unless you really want to pay that kind of cash.
i have a set of almost new springs that came with a 77 2wd blazer. i also know a guy who had some brand new ones last time i talked to him. i can ask if you'd like.
Well, tell me if this is a bad idea. I think I going to buy front and rear 2" add a leafs from topguncustomz.com, looks like shipped its only going to cost $175.00 for all of it. Im hoping that it will stiffen it up enough.
I've had good luck with tgc. they ship quickly. It may stiffen up your ride quite a bit but it is an option.
