I copied the 14 bible and gear install from pirate so I have the info I need. it says to torque to 300 to 350 ft lb. then start checking for the required 20 to 35 IN lb of bearing preload. says it takes upwards of 400 ft lbs to reach the preload.
I borrowed my buds Proto 600 ft lb TQ. wrench and I baught a 0 to 75 IN lb X 1 in. incerment reading AND a 0 to 250 IN lb TQ wrench with 5 in lb incerment.
I worked my way from 300 to 600 ft lb by 20 lb incerments wrench and only have 10 to 12 in lb of preload!!
what gives??? do I just keep going??
thanks for any help given.
