MEMO43
Ok this one has me baffled, I need some reassurance.
My 83 k5 blazer sbc 350(crate 700 r4 with np208. I believe 3.08 gears don't recall.
I purchase the rig a little over 2 years ago.
it originally had auto hubs which of course were not functioning, swapped them out with some warn hubs, had the tcase gone through an adjusted.
I dont recall having any issues in 4 hi in the past.
recently I had a failure with the front hub.
swapped them out.
Here is were I need reassurance
Place the blazer on jackstands an engaged the 4hi the rear tires spin, the driver side tires spin but the pass does not. is this normal or is it because of limited slip. Verified that the hubs are engaged an the axles spin.
when I unlocked them no axle spin with is normal
When I put the hubs back I actually read the instructions again to make sure I was doing everything correct. The only thing I could not do was get the snap ring on the axle shaft installed, according to the warn instructions this is fine an will not void anything.
any help would be appreciated
swapped them out.
