The short answer... head lights. It's a little complicated to explain though. Here goes.
I put a 91 front clip in my 86 K5 Blazer. My 86 lights had a high beam headlight with 2 prongs (negative and high beam positive). My 86 also had a low beam headlight with 3 prongs (negative, low beam positive, and high beam positive).
My new (91) lights are not setup for that. The low beam only has two prongs (negative and postive). So, with that said, I can either have a low or a high beam turned on (not both). My dash high/low beam wiring is only a single low beam wire and a single high beam wire. Only one wire is hot at a time depending of if you are using high or low beams. When you are running low beams, the high beam wire is not hot and visa-versa. It's physically impossible to illuminate both high and low beam headlights without a relay to isolate the two.
