with a 400 and the 203 that comes with the 73, i'd have
"First gear: 2.48 x T-case low: 2.01 x Differential: 5.13 = Final Drive: 25.57"
that just sucks, so what i'm thinking is either a doubler which would give me
"Underdrive: 2.01 x First gear: 2.48 x T-case low: 1.96 x Differential: 5.13 x Final Drive: 50.12"
which is just over the 43 that i'm at currently, now the last option is
465-205 which would give me
"First gear: 6.54 x T-case low: 1.96 x Differential: 5.13 = Final Drive: 65.76"
which would be great, but do you think the torque from caddy will be fine with the 50 crawl ratio
so basicaly heres my options right?
25 crawl ratio just via tranny/t-case
50 crawl ratio via doubler
65 ratio with 465-205......
opinions? /forums/images/graemlins/ears.gif
Brandon,
Double the value for 1st Gear in any automatic transmission. The stall converter gives you "slip" that decouples the engine rpms from the tranny. (at least at RPMs that are below the stall speed, which they will be if you're crawling) Most people will calculate that TH400 ratio as: 2.48 X2 = 4.96
Still not quite as deep as a 465, but not nearly as far away as you've indicated either.... /forums/images/graemlins/cool.gif
Brandon,
