I wanted a lift in my garage since day one...but finances ran dry before I got to that point,I still have the rear door opening covered with plywood since I built it in '92,never did get a "real" electrical service put in it either...dont forget you'll probably need 220V to run the lift motor--that alone costs as much as a used lift will in many cases..
After being around many lifts in commercial garages,I would not want a 2 post lift,I dislike them a lot--they not only have more potential for tearing out of the floor,but they often are just plain scary when certain vehicles are on them,and the pads that lift the vehicle can slip easily if your torquing on a bolt hard or prying something into position..
My friend had an 11K lift that had two drive on ramps,it had two 12' lengths of channel iron under it that contained the hydraulic pistons--it was used mostly for wheel alignments,but was excellent for just about any other job--it had a air jack that slid on a carriage between the two ramps ,so you can lift either end of the vehicle up for tire changes,brake jobs,etc,and the open center made for easy access to mufflers and tranny's,and the jack could be used to lift the tranny into position..
I liked that lift a lot,and like an idiot,I balked at taking it when the bussiness was sold off,and the new owner wanted all NEW lifts and eqiupment put in!--another guy grabbed it before I had a chance to make up my mind..I think its still sitting in the weeds right where he left it,at a house he lost to forclosure..bet its scrapped by now..
There was a "mid rise" lift in one bay at that shop too--what a POS,I wouldn't take it as a gift--was best for crushing exhaust systems and bending driveshafts ,you cant get under it since it lifts only 3' high,and there's NO access to the underside of the vehicle..its only good for brake & tire repairs...he also had a "FIAP" two post 6K lift I could have had free too,but he'd had numerous problems with it ,it used an acme thread screw as the lifting device,and twice the bronze "nuts" that bore the brunt of the lift force stripped out,despite faithfull greasing,and it had a motorcycle drive chain under a plate that spanned the 2 posts that would de-rail at the worst possible moment or snap--also had a timing belt drive setup to the motor that had issues too..I passed on it..still regret letting that 4 post lift slip by,I could have installed it on my 4" thick floor with no issues at all,in fact the shop it was in only had 3" of concrete in most of the floor,and they never had any sign of concrete damage,and they put one ton dually utility trucks on it all the time...
