Need some 4 core radiator brackets.
I believe it's one solid piece that goes across. My cousin put a bigblock 4core in and used that engines radiator brackets. You can always make yours work too. I just cut and bent mine to work.
just saying
sorry, don't have one :)
The top brackets for an '84 are two seperate and small brackets with a plastic strip in between them. I may have an extra pair, I will check my parts shelf.
Ahh, well I don't know the details, sorry for posting fuzzy info lol. But his is an 85 3/4 p/u. I think the rad and mounts came from either an 89 3/4 bbc suburban or 70s dually. Each gave up an axle for his truck, so that's where the mounts may have come from.
All that matters is what core support he is using. 80 down use the one piece bracket, 81 up use the two brackets.
