3MAX
I've been browsing here for quite a while as I get ready to do a build up of my own. I've got a pretty good idea of what I want, but still have a few remaining questions / decisions.
Here's my plan, starting with a stock '90 model, in pretty good shape -
383, Vortec heads, mild roller cam, headers
Rebuilt 700R4
14 bsf rear axle
stock 10 bolt front
4" lift
35" KM2's
The blazer will see approximately 30% towing with 4000-5000lbs, 30% camping & hunting 20% trails & offroading, and 20% crusing with the top off.
My main goal is reliability and towing power. This truck will see plenty of highway / interstate towing at 75 mph.
So here are my questions (feel free to give advice on anything I've missed as well).
1. Keep the TBI or go to carb? I'm more comfortable with a carb, as I have no experience with TBI, and I'm somewhat intimidated by the thought of customizing this system to keep up with the 383.
2. 4.10 or 4.56 gears? I want to be able to tow at 75mph, and I will not be running the 700R4 in OD while towing.
3. Detroit Locker or selectable locker in rear? (The front will be getting a True-Trac).
4. What brand lift do you suggest? I'm really leaning toward a full "off the shelf" system rather than using blocks or a shackle flip in the rear. My rear spring bushings are shot, and I don't mind giving up some flex in order to have a higher spring rate for better handling while towing.
I plan to purchase all my parts and everything available before I start the tear down. Once I get started, I'll post the build up here.
Thanks in advance for the help.
Rebuilt 700R4
14 bsf rear axle
stock 10 bolt front
4" lift
35" KM2's
. i'm reading/learning the trick with TBI is to use a sensible cam that'll work with the computer. build the motor to run optimum for the way YOU plan on using it. low down torque is your friend, build that......big HP at 5000 rpm makes as much sense as an elevator in an outhouse for what you seem to want to do. all imo of course, Bill
