My K5 has a 75 frame, and a 77 body
I could use a couple measurements:
The thickness of the bodymount at the firewall floorboard mount.
The distance between the rear body crossmember, and the frame mounting point for the rear most bodymount.
Is the floorboard body structure parallel with the frame, or is it angled toward the front or back?
The set of mounts that my truck had are aftermarket I believe, and I need some help with what goes where. Some were in a box, and some on the truck when I got the truck, so I don't know what goes where.
Here are some pics..they are in order by their stamped numbers:
Bottom row left to right I have the following:
2-4008
2-4009
4-4010
2-4011
Top row
2-4025
6-4037
2-4092
Some of these have different inside diameters, and all of the numbers have different overall height to them.
There are also different bushings and washer sizes:
2 Different bushings, both outside diameters the same, but the thickness of one is .0625, the other is .125
3 different sized washers/shims...2", 2.5", 3"
This is how they might go together, trying to look at the LMC book to see what was original stuff...these don't quite match up.
layed out Front to Back, with the left being the core support, and right being the rear.
2-4008
2-4009
4-4010
2-4011
Top row
2-4025
6-4037
2-4092
