Need some carpet, or something to quiet her down.
us74k5
oregon
So everything works pretty good so far, however the blazer is pretty damn loud when im inside it. I think i need something to put down over my line-x'd floor. Any suggestions? Something preferably durable, or cheap and easily replaced. Bust most of all, able to cut down the noise significantly.
ear plugs are cheaper and easier. I'm in the same boat as you with a loud set of swampers and an exhaust that dumps under the truck. The heat is misserable too. That with no AC and a broken right window motor, summer was HOT, can't roll down the back window or I get sleepy from the fumes.
lol, sounds like our trucks are identical:-) Luckily its cold up here in washington, I dont even need to use the heater:-D
same here. i just picked up a used carpet in decent shape, just to quiet the inside. I'm also gonna run a tailpipe instead of having it dumped. i might even pick up a set of 37" goodyear humvee tires for the street.
