xenomarine
i found on craigslist, the axles/diffs from a 76 k20. which i am almost positive to be a D44 and a 14bolt. the gearing is not listed in the ad, but they are $100 each of $150 for the pair.
should i be running over there and buying them? this would be to swap onto my '84 blazer wih 10bolts all around. what else would i need for the swap? brake lines, u-joint parts? steering parts? i'm not sure on all the specifics of an axle swap but i have alot of general knowledge from reading.
also, does anyone know the stock gearing that came on a K20 of the same vintage? and i know axles aren't exactly light, but could my friend and i load them in a truck? what is the typical weight for an axle assembly?
