Dad has a 98 Ford F250 with a 5.4L Trition engine in it. MPSFI with coil on plug ignition.
The engine won't start from cold, and has to be cranked for 20 - 30 seconds before it will finally fire and start. When it does, it usually revs up to around 1200 rpm, then stalls out. It does that 2 or 3 times before it will finally run. Any attempt to touch the throttle will kill it immediately. Any attempt to put it in gear results in the same. When it does run cold, it has a noticeble lean miss to it, and the exhaust smells strongly, like a lean carbed engine would.
I've got an OBDII scanner that I've hooked up to it, and all the sensors seem to be reading normal. IAT and ECT both read within a few degrees of eachother before you start the truck, and are close to ambient temperatures. The ECT reaches 195F as expected as the truck reaches operating temperature. The mass air flow meter ranges from 1.7 lb/min at 1000 rpm to 7.5 lb/min at 4000 rpm. The ambient air temperature is approx 5°F.
I plotted the RPM vs mass air flow rate, and it does make a fairly linear line, so I think that the mass air meter is alright. The MAP sensor reads normal ambient as well.
Truck has brand new plugs / plug boots (had the issue before) and it runs & starts perfectly normal when it is at operating temperature. I just also just replaced the fuel filter & the injector filter baskets, and am fairly convinced that it is not a fuel supply issue.
Anyone have any ideas of what might be ailing this truck? I can't figure it out, and usually don't have so much trouble with EFI issues
